Hello there
I ran the following command. Its made a mistake
systemctl start grafana-server
*Job for grafana-server.service failed because the control process exited with error code. See “systemctl status grafana-server.service” and “journalctl -xe” for details.
● grafana-server.service - Grafana instance
Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: disabled)
Active: failed (Result: start-limit) since Çrş 2019-03-20 16:02:47 +03; 12s ago
Docs: http://docs.grafana.org
Process: 4725 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=rpm cfg:default.paths.logs=${LOG_DIR} cfg:default.paths.data=${DATA_DIR} cfg:default.paths.plugins=${PLUGINS_DIR} cfg:default.paths.provisioning=${PROVISIONING_CFG_DIR} (code=exited, status=1/FAILURE)
Main PID: 4725 (code=exited, status=1/FAILURE)
Mar 20 16:02:46 localhost.localdomain systemd[1]: grafana-server.service: main process exited, code=exited, status=1/FAILURE
Mar 20 16:02:46 localhost.localdomain systemd[1]: Failed to start Grafana instance.
Mar 20 16:02:46 localhost.localdomain systemd[1]: Unit grafana-server.service entered failed state.
Mar 20 16:02:46 localhost.localdomain systemd[1]: grafana-server.service failed.
Mar 20 16:02:47 localhost.localdomain systemd[1]: grafana-server.service holdoff time over, scheduling restart.
Mar 20 16:02:47 localhost.localdomain systemd[1]: Stopped Grafana instance.
Mar 20 16:02:47 localhost.localdomain systemd[1]: start request repeated too quickly for grafana-server.service
Mar 20 16:02:47 localhost.localdomain systemd[1]: Failed to start Grafana instance.
Mar 20 16:02:47 localhost.localdomain systemd[1]: Unit grafana-server.service entered failed state.
Mar 20 16:02:47 localhost.localdomain systemd[1]: grafana-server.service failed.
[root@localhost ~]# ^C
[root@localhost ~]# nano /etc/grafana/grafana.ini
[root@localhost ~]# systemctl status grafana-server
Active: failed (Result: start-limit) since Çrş 2019-03-20 16:02:47 +03; 5min ago
Have a look at the Grafana log, often it is /var/log/grafana/grafana.log.
LOGS;
t=2019-03-20T06:24:44+0300 lvl=info msg=“cleanup of expired auth tokens done” logger=auth count=0
t=2019-03-20T15:46:22+0300 lvl=info msg=“Shutdown started” logger=server reason=“System signal: terminated”
t=2019-03-20T15:46:22+0300 lvl=info msg=“Stopped UsageStatsService” logger=server reason=“context canceled”
t=2019-03-20T15:46:22+0300 lvl=info msg=“Stopped PluginManager” logger=server reason=“context canceled”
t=2019-03-20T15:46:22+0300 lvl=info msg=“Stopped CleanUpService” logger=server reason=“context canceled”
t=2019-03-20T15:46:22+0300 lvl=info msg=“Stopped UserAuthTokenService” logger=server reason=“context canceled”
t=2019-03-20T15:46:22+0300 lvl=info msg=“Stopped ProvisioningService” logger=server reason=“context canceled”
t=2019-03-20T15:46:22+0300 lvl=info msg=“Stopped Stream Manager”
t=2019-03-20T15:46:22+0300 lvl=info msg=“Stopped RenderingService” logger=server reason=nil
t=2019-03-20T15:46:22+0300 lvl=info msg=“Stopped NotificationService” logger=server reason=“context canceled”
t=2019-03-20T15:46:22+0300 lvl=info msg=“Stopped TracingService” logger=server reason=nil
t=2019-03-20T15:46:22+0300 lvl=info msg=“Stopped InternalMetricsService” logger=server reason=“context canceled”
t=2019-03-20T15:46:22+0300 lvl=info msg=“Stopped AlertingService” logger=server reason=“context canceled”
t=2019-03-20T15:46:22+0300 lvl=info msg=“Stopped HTTPServer” logger=server reason=nil
t=2019-03-20T15:46:22+0300 lvl=eror msg=“Server shutdown” logger=server reason=“System signal: terminated”
t=2019-03-20T15:46:57+0300 lvl=info msg=“Starting Grafana” logger=server version=6.0.2 commit=3f4c2e7 branch=HEAD compiled=2019-03-19T16:06:06+0300
t=2019-03-20T15:46:57+0300 lvl=info msg=“Config loaded from” logger=settings file=/usr/share/grafana/conf/defaults.ini
t=2019-03-20T15:46:57+0300 lvl=info msg=“Config loaded from” logger=settings file=/etc/grafana/grafana.ini
t=2019-03-20T15:46:57+0300 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.data=/var/lib/grafana”
t=2019-03-20T15:46:57+0300 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.logs=/var/log/grafana”
t=2019-03-20T15:46:57+0300 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.plugins=/var/lib/grafana/plugins”
t=2019-03-20T15:46:57+0300 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.provisioning=/etc/grafana/provisioning”
t=2019-03-20T15:46:57+0300 lvl=info msg=“Path Home” logger=settings path=/usr/share/grafana
t=2019-03-20T15:46:57+0300 lvl=info msg=“Path Data” logger=settings path=/var/lib/grafana
t=2019-03-20T15:46:57+0300 lvl=info msg=“Path Logs” logger=settings path=/var/log/grafana
t=2019-03-20T15:46:57+0300 lvl=info msg=“Path Plugins” logger=settings path=/var/lib/grafana/plugins
t=2019-03-20T15:46:57+0300 lvl=info msg=“Path Provisioning” logger=settings path=/etc/grafana/provisioning
t=2019-03-20T15:46:57+0300 lvl=info msg=“App mode production” logger=settings
t=2019-03-20T15:46:57+0300 lvl=info msg=“Writing PID file” logger=server path=/var/run/grafana/grafana-server.pid pid=3896
t=2019-03-20T15:46:57+0300 lvl=info msg=“Initializing HTTPServer” logger=server
t=2019-03-20T15:46:57+0300 lvl=info msg=“Initializing SqlStore” logger=server
t=2019-03-20T15:46:57+0300 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=mysql
t=2019-03-20T15:46:57+0300 lvl=info msg=“Starting DB migration” logger=migrator
t=2019-03-20T15:46:57+0300 lvl=eror msg=“Server shutdown” logger=server reason=“Service init failed: Migration failed err: dial tcp 127.0.0.1:3306: connect: connection refused”
t=2019-03-20T15:46:57+0300 lvl=info msg=“Writing PID file” logger=server path=/var/run/grafana/grafana-server.pid pid=4219
That suggests that possibly your mysql server is not running.
any resolution. Since i am also facing the similar issue
remove grafana and make sure the grafana directory is also deleted, because it does go not by its own > then reinstall grafana , reconfigure grafana.conf server as before when it worked .
Also stop firewall completely or create an rule for port 3000 .
