My Grafana is starting to failed, As it was failing I upgraded it without taking backup Here are some details of files and error -
Config files:
/usr/share/grafana/conf/defaults.ini
/etc/grafana/grafana.ini
Command lines overrides:
data=/var/lib/grafana (plugins,csv,alerting files)
logs=/var/log/grafana
systemctl start grafana-server
Job for grafana-server.service failed because the control process exited with error code. See "systemctl status grafana-server.service" and "journalctl -xe" for details.
And Status systemctl status grafana-server
● grafana-server.service - Grafana instance
Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: disabled)
Active: failed (Result: start-limit) since Tue 2024-07-30 05:37:25 UTC; 6min ago
Docs: http://docs.grafana.org
Process: 1341 ExecStart=/usr/share/grafana/bin/grafana server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=rpm cfg:default.paths.logs=${LOG_DIR} cfg:default.paths.data=${DATA_DIR} cfg:default.paths.plugins=${PLUGINS_DIR} cfg:default.paths.provisioning=${PROVISIONING_CFG_DIR} (code=exited, status=1/FAILURE)
Main PID: 1341 (code=exited, status=1/FAILURE)
Jul 30 05:37:25 analytics-app-vm systemd[1]: Failed to start Grafana instance.
Jul 30 05:37:25 analytics-app-vm systemd[1]: Unit grafana-server.service entered failed state.
Jul 30 05:37:25 analytics-app-vm systemd[1]: grafana-server.service failed.
Jul 30 05:37:25 analytics-app-vm systemd[1]: grafana-server.service holdoff time over, scheduling restart.
Jul 30 05:37:25 analytics-app-vm systemd[1]: Stopped Grafana instance.
Jul 30 05:37:25 analytics-app-vm systemd[1]: start request repeated too quickly for grafana-server.service
Check the logs of grafana (not grafana service).
I could only find logs here var/log/grafana/
logger=remotecache.database t=2024-07-29T03:08:54.570915254Z level=error msg="failed to run garbage collect" error="dial tcp 127.0.0.1:3306: connect: connection refused"
logger=cleanup t=2024-07-29T03:08:54.571418316Z level=error msg="Failed to delete expired snapshots" error="dial tcp 127.0.0.1:3306: connect: connection refused"
logger=cleanup t=2024-07-29T03:08:54.571642321Z level=error msg="Failed to delete expired dashboard versions" error="dial tcp 127.0.0.1:3306: connect: connection refused"
logger=cleanup t=2024-07-29T03:08:54.571844123Z level=error msg="Failed to delete expired images" error="dial tcp 127.0.0.1:3306: connect: connection refused"
logger=cleanup t=2024-07-29T03:08:54.572223771Z level=error msg="Problem expiring user invites" error="dial tcp 127.0.0.1:3306: connect: connection refused"
logger=cleanup t=2024-07-29T03:08:54.572462742Z level=error msg="Problem deleting stale short urls" error="dial tcp 127.0.0.1:3306: connect: connection refused"
logger=cleanup t=2024-07-29T03:08:54.57266656Z level=error msg="Problem deleting stale query history" error="dial tcp 127.0.0.1:3306: connect: connection refused"
logger=cleanup t=2024-07-29T03:08:54.572840098Z level=error msg="Problem with enforcing row limit for query_history" error="dial tcp 127.0.0.1:3306: connect: connection refused"
logger=cleanup t=2024-07-29T03:08:54.573063587Z level=error msg="Problem with enforcing row limit for query_history_star" error="dial tcp 127.0.0.1:3306: connect: connection refused"
logger=cleanup t=2024-07-29T03:08:54.573199308Z level=info msg="Completed cleanup jobs" duration=2.659244ms
logger=grafana.update.checker t=2024-07-29T03:08:54.667290198Z level=info msg="Update check succeeded" duration
logger=ngalert.scheduler t=2024-07-29T03:09:00.000555247Z level=error msg="Failed to update alert rules" error="failed to get alert rules: failed to fetch alert rules: dial tcp 127.0.0.1:3306: connect: connection refused"
Milions errors about database - it’s not able to connect to db. Fix that and one problem solved.
Please format logs.
To resolve the Grafana startup issue, first check the logs for specific error messages using journalctl -xe and systemctl status grafana-server. Verify the integrity and correctness of the configuration files located at /usr/share/grafana/conf/defaults.ini and /etc/grafana/grafana.ini. Ensure that Grafana has the correct permissions for directories /var/lib/grafana and /var/log/grafana. If you encounter issues with backups, temporarily remove or rename the existing backup files. Restart the Grafana service using sudo systemctl restart grafana-server. If the issue persists, consider reinstalling Grafana.
Shanker Agarwal
(Grafana Architect)
shanker.agarwal@dataabsolute.com
