System Admin can't see Server Admin Settings link
Just did a fresh install of Grafana 7.0.3 and enabled https/ssl. When I log into the control panel with the default Super Admin user, the “Server Admin” link under Configuration is not visible. I can’t figure out what I did to disable it or how to re-enable it.
