Grafana Server Admin Settings
I am using Grafana cloud and I am trying to change some Server Admin settings. I have been referred to the Configuration page, but I still have some questions.
I downloaded Grafana onto my PC and can find the pathway and the custom.ini file.
I changed the settings I would like to change, but this is not reflected in my organization’s Server Admin Settings in Grafana. This makes sense to me because just because I downloaded Grafana does not link the custom.ini file to my organization’s Grafana server in any way.
How do I link the custom.ini file on my PC to change the Server Admin settings for my organization’s Grafana server?
I am hoping to change the auto-logout duration to be a longer length, but the Configuration page details that pretty clearly once I learn to change any settings using the custom.ini file.
My version is v7.3.7
Thanks!
Hi @rdh1 - it sounds like you are running a local instance of Grafana OSS. If you are using Grafana Cloud - our SaaS version of Grafana - you’d be accessing a URL like rdh1.grafana.net.
If you’re having issues accessing your Grafana Cloud / SaaS account, feel free to open a support ticket and we’ll look into it for you!
David
