Hi @takahiromasuda! To make sure I understand your inquiry, are you asking why such high latency appears in milliseconds rather than seconds? Or are you curious why the network latency for that check is so high?
If the latter, there are many reasons why a network request might have high latency. The guide below discusses this further:
How traceroute in the Synthetic Monitoring plugin for Grafana Cloud helps network troubleshooting
In the meantime, I’ll open a feature request for showing high latency in seconds rather than milliseconds.
Yes the network latency check is high and doesn’t represent the traceroutes latency.
hi any update regarding this?
Hi Melody,
Any update on this bug?
