Synthetic checks for Fastly CDN fronted sites timing out
  • What Grafana version and what operating system are you using? - Cloud
  • What are you trying to achieve? - Unauthenticated https checks of my various websites (200 response)
  • How are you trying to achieve it? OOTB Synthetic Monitors
  • What happened? Checks run, but randomly time out throughout the day triggering alerts. Increased timeout for simply 200 check to 10 seconds and it’s still failing. Grafana AI says Fastly is the problem, but all of our sites are working fine and NewRelic is not alerting.
  • What did you expect to happen? Checks to run successfully. I’m migrating from NewRelic and they don’t time out in that system.
  • Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. - context deadline exceeded
    All of my sites throw context deadline exceeded with a 10 second timeout for basic API and WWW 200 response checks randomly. No performance problems experienced for end users and my other synthetics running in NewRelic are fine. Sites are hosted behind Fastly without a WAF. Origin in Fastly is AWS ALB. I’ve had to disable all of my checks due to the volume of 10+ second timeouts. Fastly shielding and ALB are both in US-West so I tried all west Synthetic locations with the same issue. Any ideas? Thanks!
