Synology grafana
Hello Community,
I have Grafana (Graph) which contains some graphs (server-monitoring - firewall monitoring)
I wonder if there is a possibility to supervise my synology NAS through Grafana, indeed, I want to add some graphs for the supervision of my synology NAS to my grafana (already installed) ?
If you have any instructions or blogs to follow please share them with me
Thanks
Grafana can display data from a number of different data sources:
If you can get whatever it is you want to measure / monitor about your
Synology NAS into one of those data sources, Grafana can display it for you.
Grafana itself does not measure or monitor anything - it simply displays data
which has been put into a data source by some other program / script /
application.
Antony.
I thank you for your quick answer.
Can you suggest me some blogs to follow or some instructions to achieve this result?
Joe
Well, a Google search for “Grafana Synology NAS” shows me:
I hope those give you some useful guidance.
Antony.
Thanks for sharing Antony !!
