Dear all,
I’m monitoring my Synology in Grafan with Prometheus
and would like to add USB Volume to the dashboard, would someone help me out, how could I do that? I’d like to add it so I can see the data like size and temperature.
Thank you!
KR
Rok
@mlinko6
Do you have a config or yaml file that you can share here?
@grant2 Which Yaml or Config do you need? The Dashboard config or the portainer yaml file with all the docker containers?
The yaml or whatever exporter file you have configured to send the data to Prometheus.
Here is the config:
auths:
snmpv3:
version: 3
security_level: authPriv
auth_protocol: MD5
username: ***********
password: ***********
priv_protocol: DES
priv_password: *************
modules:
synology:
walk:
- 1.3.6.1.2.1.2 # network
- 1.3.6.1.2.1.31.1.1 # The total number received/transmitted of the interface
- 1.3.6.1.4.1.6574.1 # displays all system statuses
- 1.3.6.1.4.1.6574.2 # information regarding hard drives e.g Temperature
- 1.3.6.1.4.1.6574.3 # monitoring RAID status
- 1.3.6.1.4.1.6574.6 # the number of users logging in
metrics:
- name: ifNumber
oid: 1.3.6.1.2.1.2.1
type: gauge
help: The number of network interfaces (regardless of their current state) present
on this system. - 1.3.6.1.2.1.2.1
- name: ifIndex
oid: 1.3.6.1.2.1.2.2.1.1
type: gauge
help: A unique value, greater than zero, for each interface - 1.3.6.1.2.1.2.2.1.1
indexes:
- labelname: ifIndex
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
oid: 1.3.6.1.2.1.31.1.1.1.1
type: DisplayString
- labels:
labelname: ifIndex
- name: ifDescr
oid: 1.3.6.1.2.1.2.2.1.2
type: DisplayString
help: A textual string containing information about the interface - 1.3.6.1.2.1.2.2.1.2
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifMtu
oid: 1.3.6.1.2.1.2.2.1.4
type: gauge
help: The size of the largest packet which can be sent/received on the interface,
specified in octets - 1.3.6.1.2.1.2.2.1.4
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifSpeed
oid: 1.3.6.1.2.1.2.2.1.5
type: gauge
help: An estimate of the interface’s current bandwidth in bits per second - 1.3.6.1.2.1.2.2.1.5
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifPhysAddress
oid: 1.3.6.1.2.1.2.2.1.6
type: PhysAddress48
help: The interface’s address at its protocol sub-layer - 1.3.6.1.2.1.2.2.1.6
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifAdminStatus
oid: 1.3.6.1.2.1.2.2.1.7
type: gauge
help: The desired state of the interface - 1.3.6.1.2.1.2.2.1.7
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
enum_values:
1: up
2: down
3: testing
- name: ifOperStatus
oid: 1.3.6.1.2.1.2.2.1.8
type: gauge
help: The current operational state of the interface - 1.3.6.1.2.1.2.2.1.8
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
enum_values:
1: up
2: down
3: testing
4: unknown
5: dormant
6: notPresent
7: lowerLayerDown
- name: ifLastChange
oid: 1.3.6.1.2.1.2.2.1.9
type: gauge
help: The value of sysUpTime at the time the interface entered its current operational
state - 1.3.6.1.2.1.2.2.1.9
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifInOctets
oid: 1.3.6.1.2.1.2.2.1.10
type: counter
help: The total number of octets received on the interface, including framing
characters - 1.3.6.1.2.1.2.2.1.10
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifInUcastPkts
oid: 1.3.6.1.2.1.2.2.1.11
type: counter
help: The number of packets, delivered by this sub-layer to a higher (sub-)layer,
which were not addressed to a multicast or broadcast address at this sub-layer
- 1.3.6.1.2.1.2.2.1.11
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifInNUcastPkts
oid: 1.3.6.1.2.1.2.2.1.12
type: counter
which were addressed to a multicast or broadcast address at this sub-layer -
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifInDiscards
oid: 1.3.6.1.2.1.2.2.1.13
type: counter
help: The number of inbound packets which were chosen to be discarded even though
no errors had been detected to prevent their being deliverable to a higher-layer
protocol - 1.3.6.1.2.1.2.2.1.13
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifInErrors
oid: 1.3.6.1.2.1.2.2.1.14
type: counter
help: For packet-oriented interfaces, the number of inbound packets that contained
errors preventing them from being deliverable to a higher-layer protocol - 1.3.6.1.2.1.2.2.1.14
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifInUnknownProtos
oid: 1.3.6.1.2.1.2.2.1.15
type: counter
help: For packet-oriented interfaces, the number of packets received via the interface
which were discarded because of an unknown or unsupported protocol - 1.3.6.1.2.1.2.2.1.15
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifOutOctets
oid: 1.3.6.1.2.1.2.2.1.16
type: counter
help: The total number of octets transmitted out of the interface, including framing
characters - 1.3.6.1.2.1.2.2.1.16
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifOutUcastPkts
oid: 1.3.6.1.2.1.2.2.1.17
type: counter
help: The total number of packets that higher-level protocols requested be transmitted,
and which were not addressed to a multicast or broadcast address at this sub-layer,
including those that were discarded or not sent - 1.3.6.1.2.1.2.2.1.17
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifOutNUcastPkts
oid: 1.3.6.1.2.1.2.2.1.18
type: counter
and which were addressed to a multicast or broadcast address at this sub-layer,
including those that were discarded or not sent - 1.3.6.1.2.1.2.2.1.18
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifOutDiscards
oid: 1.3.6.1.2.1.2.2.1.19
type: counter
help: The number of outbound packets which were chosen to be discarded even though
no errors had been detected to prevent their being transmitted - 1.3.6.1.2.1.2.2.1.19
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifOutErrors
oid: 1.3.6.1.2.1.2.2.1.20
type: counter
help: For packet-oriented interfaces, the number of outbound packets that could
not be transmitted because of errors - 1.3.6.1.2.1.2.2.1.20
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifOutQLen
oid: 1.3.6.1.2.1.2.2.1.21
type: gauge
help: The length of the output packet queue (in packets). - 1.3.6.1.2.1.2.2.1.21
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifSpecific
oid: 1.3.6.1.2.1.2.2.1.22
type: OctetString
help: A reference to MIB definitions specific to the particular media being used
to realize the interface - 1.3.6.1.2.1.2.2.1.22
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifName
type: DisplayString
help: The textual name of the interface - 1.3.6.1.2.1.31.1.1.1.1
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifInMulticastPkts
oid: 1.3.6.1.2.1.31.1.1.1.2
type: counter
which were addressed to a multicast address at this sub-layer - 1.3.6.1.2.1.31.1.1.1.2
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifInBroadcastPkts
oid: 1.3.6.1.2.1.31.1.1.1.3
type: counter
which were addressed to a broadcast address at this sub-layer - 1.3.6.1.2.1.31.1.1.1.3
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifOutMulticastPkts
oid: 1.3.6.1.2.1.31.1.1.1.4
type: counter
and which were addressed to a multicast address at this sub-layer, including
those that were discarded or not sent - 1.3.6.1.2.1.31.1.1.1.4
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifOutBroadcastPkts
oid: 1.3.6.1.2.1.31.1.1.1.5
type: counter
and which were addressed to a broadcast address at this sub-layer, including
those that were discarded or not sent - 1.3.6.1.2.1.31.1.1.1.5
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifHCInOctets
oid: 1.3.6.1.2.1.31.1.1.1.6
type: counter
characters - 1.3.6.1.2.1.31.1.1.1.6
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifHCInUcastPkts
oid: 1.3.6.1.2.1.31.1.1.1.7
type: counter
- 1.3.6.1.2.1.31.1.1.1.7
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifHCInMulticastPkts
oid: 1.3.6.1.2.1.31.1.1.1.8
type: counter
which were addressed to a multicast address at this sub-layer - 1.3.6.1.2.1.31.1.1.1.8
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifHCInBroadcastPkts
oid: 1.3.6.1.2.1.31.1.1.1.9
type: counter
which were addressed to a broadcast address at this sub-layer - 1.3.6.1.2.1.31.1.1.1.9
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifHCOutOctets
oid: 1.3.6.1.2.1.31.1.1.1.10
type: counter
characters - 1.3.6.1.2.1.31.1.1.1.10
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifHCOutUcastPkts
oid: 1.3.6.1.2.1.31.1.1.1.11
type: counter
including those that were discarded or not sent - 1.3.6.1.2.1.31.1.1.1.11
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifHCOutMulticastPkts
oid: 1.3.6.1.2.1.31.1.1.1.12
type: counter
those that were discarded or not sent - 1.3.6.1.2.1.31.1.1.1.12
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifHCOutBroadcastPkts
oid: 1.3.6.1.2.1.31.1.1.1.13
type: counter
those that were discarded or not sent - 1.3.6.1.2.1.31.1.1.1.13
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifLinkUpDownTrapEnable
oid: 1.3.6.1.2.1.31.1.1.1.14
type: gauge
help: Indicates whether linkUp/linkDown traps should be generated for this interface
- 1.3.6.1.2.1.31.1.1.1.14
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
enum_values:
1: enabled
2: disabled
- name: ifHighSpeed
oid: 1.3.6.1.2.1.31.1.1.1.15
type: gauge
help: An estimate of the interface’s current bandwidth in units of 1,000,000 bits
per second - 1.3.6.1.2.1.31.1.1.1.15
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifPromiscuousMode
oid: 1.3.6.1.2.1.31.1.1.1.16
type: gauge
help: This object has a value of false(2) if this interface only accepts packets/frames
that are addressed to this station - 1.3.6.1.2.1.31.1.1.1.16
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
enum_values:
1: “true”
2: “false”
- name: ifConnectorPresent
oid: 1.3.6.1.2.1.31.1.1.1.17
type: gauge
help: This object has the value ‘true(1)’ if the interface sublayer has a physical
connector and the value ‘false(2)’ otherwise. - 1.3.6.1.2.1.31.1.1.1.17
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
enum_values:
1: “true”
2: “false”
- name: ifAlias
oid: 1.3.6.1.2.1.31.1.1.1.18
type: DisplayString
help: This object is an ‘alias’ name for the interface as specified by a network
manager, and provides a non-volatile ‘handle’ for the interface - 1.3.6.1.2.1.31.1.1.1.18
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: ifCounterDiscontinuityTime
oid: 1.3.6.1.2.1.31.1.1.1.19
type: gauge
help: The value of sysUpTime on the most recent occasion at which any one or more
of this interface’s counters suffered a discontinuity - 1.3.6.1.2.1.31.1.1.1.19
indexes:
type: gauge
lookups:
- labels:
- ifIndex
labelname: ifName
type: DisplayString
- labels:
labelname: ifIndex
- name: systemStatus
oid: 1.3.6.1.4.1.6574.1.1
type: gauge
help: Synology system status Each meanings of status represented describe below
- name: temperature
oid: 1.3.6.1.4.1.6574.1.2
type: gauge
help: Synology system temperature The temperature of Disk Station uses Celsius
degree. - 1.3.6.1.4.1.6574.1.2
- name: powerStatus
oid: 1.3.6.1.4.1.6574.1.3
type: gauge
help: Synology power status Each meanings of status represented describe below
- name: systemFanStatus
oid: 1.3.6.1.4.1.6574.1.4.1
type: gauge
help: Synology system fan status Each meanings of status represented describe
below - 1.3.6.1.4.1.6574.1.4.1
- name: cpuFanStatus
oid: 1.3.6.1.4.1.6574.1.4.2
type: gauge
help: Synology cpu fan status Each meanings of status represented describe below
- name: modelName
oid: 1.3.6.1.4.1.6574.1.5.1
type: DisplayString
help: The Model name of this NAS - 1.3.6.1.4.1.6574.1.5.1
- name: serialNumber
oid: 1.3.6.1.4.1.6574.1.5.2
type: DisplayString
help: The serial number of this NAS - 1.3.6.1.4.1.6574.1.5.2
- name: version
oid: 1.3.6.1.4.1.6574.1.5.3
type: DisplayString
help: The version of this DSM - 1.3.6.1.4.1.6574.1.5.3
- name: upgradeAvailable
oid: 1.3.6.1.4.1.6574.1.5.4
type: gauge
help: This oid is for checking whether there is a latest DSM can be upgraded -
- name: controllerNumber
oid: 1.3.6.1.4.1.6574.1.6
type: gauge
help: Synology system controller number Controller A(0) Controller B(1) - 1.3.6.1.4.1.6574.1.6
- name: diskIndex
oid: 1.3.6.1.4.1.6574.2.1.1.1
type: gauge
help: The index of disk table - 1.3.6.1.4.1.6574.2.1.1.1
indexes:
- labelname: diskIndex
type: gauge
lookups:
- labels:
- diskIndex
labelname: diskID
oid: 1.3.6.1.4.1.6574.2.1.1.2
type: DisplayString
- labels:
- name: diskID
type: DisplayString
help: Synology disk ID The ID of disk is assigned by disk Station. - 1.3.6.1.4.1.6574.2.1.1.2
indexes:
type: gauge
lookups:
- labels:
- diskIndex
labelname: diskID
type: DisplayString
- labels:
- name: diskModel
oid: 1.3.6.1.4.1.6574.2.1.1.3
type: DisplayString
help: Synology disk model name The disk model name will be showed here. - 1.3.6.1.4.1.6574.2.1.1.3
indexes:
type: gauge
lookups:
- labels:
- diskIndex
labelname: diskID
type: DisplayString
- labels:
- name: diskType
oid: 1.3.6.1.4.1.6574.2.1.1.4
type: DisplayString
help: Synology disk type The type of disk will be showed here, including SATA,
SSD and so on. - 1.3.6.1.4.1.6574.2.1.1.4
indexes:
type: gauge
lookups:
- labels:
- diskIndex
labelname: diskID
type: DisplayString
- labels:
- name: diskStatus
oid: 1.3.6.1.4.1.6574.2.1.1.5
type: gauge
help: Synology disk status. Normal-1 Initialized-2 NotInitialized-3 SystemPartitionFailed-4 Crashed-5
- 1.3.6.1.4.1.6574.2.1.1.5
indexes:
type: gauge
lookups:
- labels:
- diskIndex
labelname: diskID
type: DisplayString
- labels:
- name: diskTemperature
oid: 1.3.6.1.4.1.6574.2.1.1.6
type: gauge
help: Synology disk temperature The temperature of each disk uses Celsius degree.
- 1.3.6.1.4.1.6574.2.1.1.6
indexes:
type: gauge
lookups:
- labels:
- diskIndex
labelname: diskID
type: DisplayString
- labels:
- name: raidIndex
oid: 1.3.6.1.4.1.6574.3.1.1.1
type: gauge
help: The index of raid table - 1.3.6.1.4.1.6574.3.1.1.1
indexes:
- labelname: raidIndex
type: gauge
lookups:
- labels:
- raidIndex
labelname: raidName
oid: 1.3.6.1.4.1.6574.3.1.1.2
type: DisplayString
- name: raidName
type: DisplayString
help: Synology raid name The name of each raid will be showed here. - 1.3.6.1.4.1.6574.3.1.1.2
indexes:
type: gauge
lookups:
- labels:
- raidIndex
labelname: raidName
type: DisplayString
- name: raidStatus
oid: 1.3.6.1.4.1.6574.3.1.1.3
type: gauge
help: Synology Raid status Each meanings of status represented describe below
- 1.3.6.1.4.1.6574.3.1.1.3
indexes:
type: gauge
lookups:
- labels:
- raidIndex
labelname: raidName
type: DisplayString
- name: raidFreeSize
oid: 1.3.6.1.4.1.6574.3.1.1.4
type: gauge
help: Synology raid freesize Free space in bytes. - 1.3.6.1.4.1.6574.3.1.1.4
indexes:
type: gauge
lookups:
- labels:
- raidIndex
labelname: raidName
type: DisplayString
- name: raidTotalSize
oid: 1.3.6.1.4.1.6574.3.1.1.5
type: gauge
help: Synology raid totalsize Total space in bytes. - 1.3.6.1.4.1.6574.3.1.1.5
indexes:
type: gauge
lookups:
- labels:
- raidIndex
labelname: raidName
type: DisplayString
- name: serviceInfoIndex
oid: 1.3.6.1.4.1.6574.6.1.1.1
type: gauge
help: Service info index - 1.3.6.1.4.1.6574.6.1.1.1
indexes:
- labelname: serviceInfoIndex
type: gauge
lookups:
- labels:
- serviceInfoIndex
labelname: serviceName
oid: 1.3.6.1.4.1.6574.6.1.1.2
type: DisplayString
- labels:
- name: serviceName
type: DisplayString
help: Service name - 1.3.6.1.4.1.6574.6.1.1.2
indexes:
type: gauge
lookups:
- labels:
- serviceInfoIndex
type: DisplayString
- labels:
- name: serviceUsers
oid: 1.3.6.1.4.1.6574.6.1.1.3
type: gauge
help: Number of users using this service - 1.3.6.1.4.1.6574.6.1.1.3
indexes:
type: gauge
lookups:
- labels:
- serviceInfoIndex
type: DisplayString
- labels:
Inside the Synology UI, when you connect a USB hard drive, does it show a Disk ID or Disk Index anywhere? You may have to search a bit, but my guess is that it gets assigned something there. Once you know that, duplicate one or more of the gauges on your Grafana dashboard for another (internal) disk and see what the query looks like (you can paste the query here). It might be obvious where the reference to the Disk ID is. Then try changing the disk ID to the one that corresponds to the USB disk and see what happens.
Disk /dev/usb1: 3.7 TiB, 4000787029504 bytes, 7814037167 sectors
Disk model: OneTouch HDD
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 01000000-0000-0000-4E41-425238354448
This is what I can find :-), I’ll try to duplicate the Gauges but I think that I need the MIB OID for the USB drive…
