I want to move from a one, long, dashboard to many smaller dashboards.
The problem, that every time a user switches from one dashboard to the other, the time range selection, and templates values - reset to default. This is annoying, as finding the relevant time range takes time. Am I’m doing it wrong?
You can go to dashboard setting and create links to the other dashboard, links can preserve time range and variables
Thanks
It will be nice if the dashboard panel type can support this (can it?)
I am interested in such a feature, too. It has been a while. Is it possible now?
Thanks!
Hi @rmiesen,
Welcome to the
community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community ![]()
Yes, this feature is now available. You can check a live demo by going to play.grafana.com and on the upper right corner of the Dashboard you see 2 dashboard links (currently they liked to external site)
But if you into Settings (click on the gear icon) → Links → New Link
there, you add a new link and point to either another Dashboard or an external website.
Also, here is the link to the documentation.
Now, for the 2nd part i.e. to preserve the time selection. You can use the option “Include current time range”.
I hope this helps.
Thank you very much. I will give it a try.
