I have a couple dashboards that I linked together via a text panel with HTML code written in it that creates buttons (a tag) that link to other dashboards.
Now I was wondering if there was a way to remember the input that I put into the time picker when changing dashbaords. For example when I enter a timeframe from june 7th to june 14th I want the time picker to remember that input when going to another dashboard
Anybody that might know a solution?
(Grafana version 11)
How is your navigation between dashboards arranged?
You can configure Include current time range in dashboard link options:
I arrange it through a text panel. I write HTML code with a tags with the href being another dashboard. I mainly do this so I can make a nice design out of it.
Add to your URL to dashboard from and to parameters and populate them using ${__from} and ${__to} variables.
So as to get something like YOUR_EXISTING_URL&from=1718226000000&to=1718312399000
DUDE, to the rescue agane!
thanks man
