Navigation bar - time range over dashboards
Hello, Im using same principal like in this example for navigation over dashboards. But i had and problem with time range, when user select some time range on one dashboard and then switch to another, time range is used from default value of dashboard, instead of choice from previous dashboard. Is it possible to manage it somehow, that he will take his selection of timerange and not needed to select it again?
Thanks for any suggestions
