Styling additional fields in Candlestick chart
    v11.6.0
    I want to stylize executions on candlestick chart so LONG would be green color and SHORT red.
    I was trying do to is with value mapping, thresholds combined with Overrides
    “from(bucket: “backtest_data”)
    |> filter(fn: (r) => r[”_measurement"] == “exec_details”)
    |> filter(fn: (r) => r[“_field”] == “price”)
    |> group(columns: [“positionId”])
    |> map(fn: (r) => ({
    r with
    transactionType: if r.side == “BOT” then “LONG” else if r.side == “SLD” then “SHORT” else “UNKNOWN”
    |> sort(columns: [“_time”])
    |> yield(name: “processed”)
I would be very grateful for the answer!
welcome @ignacykkg
Could you please provide sample data coming from that query
Data sample in my influxdb:
this is raw data sample imported to db:
“exec_details,positionId=1,orderId=0,execId=exId1,side=BOT price=16294.5,avgPrice=16294.5,cumQty=1,shares=1 1639406039988
exec_details,positionId=2,orderId=2,execId=exId2,side=SLD price=16287.5,avgPrice=16286.75,cumQty=1,shares=1 1639406099976”
This is also output of my query inspector if thats important:
" Object
traceId:undefined
request:Object
url:“api/ds/query?ds_type=influxdb&requestId=mixed-0-SQR534”
method:“POST”
data:Object
queries:Array[2]
0:Object
refId:“A”
hide:undefined
datasource:Object
query:“from(bucket: "candle_m1") |> range(start: v.timeRangeStart, stop: v.timeRangeStop) |> filter(fn: (r) => r._measurement == "candle_m1") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> keep(columns: ["_time", "open", "high", "low", "close", "volume"])”
datasourceId:1
intervalMs:500
maxDataPoints:2500
queryCachingTTL:undefined
1:Object
refId:“B”
hide:false
datasource:Object
query:"from(bucket: "backtest_data") |> range(start: v.timeRangeStart, stop: v.timeRangeStop) |> filter(fn: (r) => r["_measurement"] == "exec_details") |> filter(fn: (r) => r["_field"] == "price") |> group(columns: ["positionId"]) |> map(fn: (r) => ({ r with transactionType: if r.side == "BOT" then "LONG" else if r.side == "SLD" then "SHORT" else "UNKNOWN" })) |> sort(columns: ["_time"]) |> yield(name: "processed") "
datasourceId:1
intervalMs:500
maxDataPoints:2500
to:“1640789449894”
hideFromInspector:false
response:Object
results:Object
A:Object
status:200
frames:Array[1]
refId:“A”
B:Object
status:200
frames:Array[11]
refId:“B”"
sorry, I meant to say the query result in grafana. what does it look like there. when you click on the Table view
Thats how table view looks like
