Change color of a query result
Grafana v8.1.2 / postgresql
Hello, I would like to know if it is possible to change the color of a specific result of a query, in the example the name “Tecnico não atribuido” would like to show in red.
You should be able to do it with Overrides > fields with name > Color scheme > Single color
Hello, thanks for the help, it has already helped me in another chart, but in this case I can’t do it for the value, but for the description, the value can change constantly but the description will always be the same
