Grafana v9.1.6 -
I’m trying to work with the Strava plugin -
Installing the Strava plugin and using the data from a Strava account as a datasource. -
What happened?
I had Strava plugin installed, and I had it connected to a Strava account: everything worked OK. But the next day the plugin gave a ‘modified signature’ and the plugin was disabled. -
I was expecting to be able to keep on seeing data from the Strava account visualised. -
Not sure how to copy and paste this. It is just that I see under the list with (All) plugins that the Strava plugin is the only one that has/is: ‘Modified signature’, ‘Disabled’ and ‘Installed’ -
See above: The Strava plugin is the only one in the list of plugins that has/is: ‘Modified signature’, ‘Disabled’ and ‘Installed’ -
No, could not find anything that could help me.
I did try to see if I could uninstall and reinstall the plugin, but I think that disabled plugins cannot be uninstalled. At least, I did not find a button for this.
I am not sure it this is something that went wrong in my own installation, or is this is something that everybody with a Strava plugin currently has, because of a wrong release or so. In that case it was just a coincidence that this generic fault happened already the first day after I installed the plugin.
