I have installed snuids-trafficlights-panel and made a simple css change to it to match our needs.
On logs the plugin is being disabled by grafana due to this change.
lvl=warn msg=“Plugin file checksum does not match signature checksum” plugin=snuids-trafficlights-panel path=/var/lib/grafana/plugins/snuids-trafficlights-panel/css/trafficlight-panel.css
I tried to use this option on grafana.ini
Enter a comma-separated list of plugin identifiers to identify plugins to load even if they are unsigned. Plugins with modified signatures are never loaded.
allow_loading_unsigned_plugins = “snuids-trafficlights-panel”
And restarting Grafana after it, but plugin remains disable and logs displaying the same message.
Is there something I am missing or can do in order to make this plugin work?
Regards,
Jose
