Dear all,
I am using Grafana Cloud. I would like to get data from my Strava Account. I installed Strava Plugin. When I want to configure Plugin and when I enter Client ID and Secret and then Click "Connect with Strava", I get "{"message":"Bad Request","errors":[{"resource":"Application","field":"redirect_uri","code":"invalid"}]}"
I always get this error, no matter what I enter. As I understand new open should Pop up, to authenticate with Strava, but instead I get above error.
If I want to save it, I get: “Cannot connect to Strava API: Refresh token not found, authorize datasource first”
Any idea?
I guess you didn’t configure Authorization Callback Domain correctly (demokedes.grafana.net):
See: https://github.com/grafana/strava-datasource/blob/master/docs/configuration.md
Authorization Callback Domain: change “Authorization Callback Domain” to localhost or any domain.
Jangaraj,
Thank you very much. This was exactly the case. After selecting the Callback domain, it started working.
