Strava erro 401
After installing the STRAVA plugin and checking the connection to the strava web page where the API query appears. When consulting the dalshboard, error 401 appears. Does anyone have an idea of how to solve it? Grafana v9.3.2
Error status: 401 Unauthorized
Object
status:500
statusText:“Internal Server Error”
data:Object
config:Object
url:“api/datasources/8/resources/strava-api”
method:“POST”
headers:Object
data:Object
retry:0
hideFromInspector:true
message:“Error status: 401 Unauthorized”
Hi @brunopi
this forum is about plugin development and not much about plugin’s support. I recommend you go to the STRAVA repository and open an issue there as it is very likely the developers don’t frequent this forum GitHub - grafana/strava-datasource: Strava datasource for Grafana dashboard
