Hi All,
I’m setting up my first Grafana Dashboard, loving the process !
I’m trying to use the Sun and Moon plugin to map the Sun’s path over my Solar Panel monitoring system. ( Sun and Moon plugin for Grafana | Grafana Labs )
This is all good, except I’m getting a strange line appearing in certain graphs, but it doesn’t always appear and seems to vary depending on the size of the graph.
As this is a plugin I’m unable to ‘change’ any settings, but if I do run a Query I cannot see any data which would link the midpoint to some other point on the right.
Hope I’m missing something simple and someone can assist ![]()
(Alternatively, is there another way to do the Sun’s path in Grafana easily?)
Grafana v7.0.3 (00ee734baf)
