Since a couple of days I have strange problems in my Grafana-Dashbaord:
Grafana suddelny isn’t connecting the points anymore, maybe it happened with the update 7.5.5 but I don’t think so.
Here are the configurations and the panel json:
→ Only two images allowed, the other two will go in the next post
"aliasColors": {
"EVU": "semi-dark-yellow",
"House": "semi-dark-red",
"PV": "semi-dark-green",
"solcast": "dark-blue"
"bars": false,
"dashLength": 10,
"dashes": false,
"datasource": "-- Mixed --",
"fieldConfig": {
"defaults": {
"links": []
"overrides": [
"matcher": {
"id": "byName",
"options": "Sun altitude"
"properties": [
"id": "displayName",
"value": "Sonnenstand"
"fill": 3,
"fillGradient": 3,
"gridPos": {
"h": 17,
"w": 24,
"x": 0,
"y": 19
"hiddenSeries": false,
"hideTimeOverride": true,
"id": 23763571993,
"interval": "",
"legend": {
"alignAsTable": false,
"avg": true,
"current": false,
"hideEmpty": false,
"hideZero": false,
"max": true,
"min": false,
"rightSide": false,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 1,
"maxPerRow": 3,
"nullPointMode": "connected",
"options": {
"alertThreshold": true
"percentage": false,
"pluginVersion": "7.5.5",
"pointradius": 2,
"points": false,
"renderer": "flot",
"repeat": null,
"repeatDirection": "h",
"seriesOverrides": [
"$$hashKey": "object:2941",
"alias": "Speicher-SoC",
"color": "#5794F2",
"dashes": true,
"fillGradient": 1,
"yaxis": 2
"$$hashKey": "object:445",
"alias": "Sonnenstand",
"color": "#FADE2A",
"dashes": true,
"yaxis": 2
"$$hashKey": "object:514",
"alias": "PV-Leisung",
"color": "#FADE2A"
"$$hashKey": "object:522",
"alias": "Netz-Leistung",
"color": "rgb(130, 130, 130)"
"$$hashKey": "object:2626",
"alias": "Hausverbrauch",
"color": "#73BF69"
"$$hashKey": "object:2635",
"alias": "PV-Prognose",
"color": "#FF9830"
"$$hashKey": "object:3144",
"alias": "Speicher-Leistung",
"color": "#5794F2"
"$$hashKey": "object:454",
"alias": "70%",
"color": "#F2495C",
"dashLength": 4,
"dashes": true,
"fillGradient": 1
"$$hashKey": "object:422",
"alias": "kWp",
"color": "#B877D9",
"dashLength": 4,
"dashes": true,
"fillGradient": 1
"spaceLength": 10,
"stack": false,
"steppedLine": false,
"targets": [
"datasource": "InfluxDB",
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"measurement": "mqtt_consumer",
"orderByTime": "ASC",
"policy": "default",
"refId": "C",
"resultFormat": "time_series",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"params": [
"* -1"
"type": "math"
"tags": [
"key": "topic",
"operator": "=",
"value": "openWB/pv/W"
"query": "SELECT mean(\"value\") * -1 FROM \"mqtt_consumer\" WHERE (\"topic\" = 'openWB/pv/W') AND $timeFilter GROUP BY time($__interval) fill(null)",
"rawQuery": true
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"hide": false,
"refId": "B",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"params": [
"*-1"
"type": "math"
"tags": [
"key": "topic",
"operator": "=",
"value": "openWB/evu/W"
"query": "SELECT mean(\"value\") *-1 FROM \"mqtt_consumer\" WHERE (\"topic\" = 'openWB/evu/W') AND $timeFilter GROUP BY time($__interval) fill(null)",
"rawQuery": true
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"hide": false,
"refId": "A",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "topic",
"operator": "=",
"value": "openWB/global/WHouseConsumption"
"query": "SELECT mean(\"value\") FROM \"mqtt_consumer\" WHERE (\"topic\" = 'openWB/global/WHouseConsumption') AND $timeFilter GROUP BY time($__interval) fill(null)",
"rawQuery": true
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"measurement": "solcast",
"policy": "autogen",
"query": "SELECT mean(\"value\") FROM \"autogen\".\"solcast\" WHERE (\"topic\" = 'pv_estimate') AND $timeFilter GROUP BY time($__interval) fill(null)",
"rawQuery": true,
"refId": "D",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "topic",
"operator": "=",
"value": "pv_estimate"
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "E",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "topic",
"operator": "=",
"value": "openWB/housebattery/W"
"query": "SELECT mean(\"value\") FROM \"mqtt_consumer\" WHERE (\"topic\" = 'openWB/housebattery/W') AND $timeFilter GROUP BY time($__interval) fill(null)",
"rawQuery": true
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "F",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "topic",
"operator": "=",
"value": "openWB/housebattery/%Soc"
"query": "SELECT mean(\"value\") FROM \"mqtt_consumer\" WHERE (\"topic\" = 'openWB/housebattery/%Soc') AND $timeFilter GROUP BY time($__interval) fill(null)",
"rawQuery": true
"datasource": "Sun and Moon",
"refId": "G",
"target": "sun_altitude"
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "PV Leistung, PV-Prognose, Sonnenstand, Netz Leistung, Speicherleistung, Speicher SoC und Hausverbrauch",
"tooltip": {
"shared": true,
"sort": 0,
"value_type": "individual"
"transformations": [
"id": "calculateField",
"options": {
"alias": "70%",
"binary": {
"left": "1",
"operator": "*",
"reducer": "sum",
"right": "6860"
"mode": "binary",
"reduce": {
"reducer": "sum"
"options": {
"alias": "kWp",
"binary": {
"left": "1",
"operator": "*",
"reducer": "sum",
"right": "9800"
"mode": "binary",
"reduce": {
"reducer": "sum"
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"$$hashKey": "object:2913",
"decimals": 2,
"format": "watt",
"label": "",
"logBase": 1,
"max": null,
"min": null,
"show": true
"$$hashKey": "object:2914",
"format": "percent",
"label": null,
"logBase": 1,
"max": "100",
"min": "0",
"show": true
"yaxis": {
"align": false,
"alignLevel": null
Any ideas?
