Stop refreshing panel when a log entry is selected
I am using Loki to to monitor logs in Grafana.
In the dashboard settings, I have the “Refresh Live Dashboard” option enabled as I need metrics to be continuously updated.
However, I want the panel where I have the logs being continuously updated, to stop refreshing once you open a log to see its details.
I know that something similar can be done from the Explore option, but I need to have this working from the custom dashboard.
Thanks!
