Refresh dashboard only after clicking on refresh button
I am using Grafana 7.5.5 on an Ubuntu machine.
My request is simple. I want to disable auto refresh of a dashboard’s panels after variables or time interval selection.
The dashboard panels should be updated only when refresh button is selected.
Do you know if it is possible to do that?
Thanks in advance!
Do you have a drop-down selector at the top right-hand corner, just next to
the Refresh button?
Use that and select “Off”.
Antony.
Thank you for your answer. Actually, It doesn’t seem to work. Whenever I change a variable’s value or update the time interval, I get an immediate refresh of the dashboard.
