I am using grafana version v9.3.2. We are pulling some data from amazon athena datasources and queries are quite large. We do not want these queries to be running automatically since there is cost associated with each time we query database. For this we have disabled the Refresh live dashboards option inside the dashboard settings. We have also enabled Hide time picker option from same set of settings. But still the dashboard refreshes when we navigate from edit panel screen to dashboard page. Is there a way this can be disabled? I want the dashboard to refresh panels only when we ask it to and not automatically. Does this have to do with configuration of grafana or version of it?
Edit - I did some digging and seems to be happening since this change TimeSrv: Don't modify refresh interval when editing panel by kaydelaney · Pull Request #51718 · grafana/grafana · GitHub
I have the same problem. Even scrolling up and down the dashboard, will cause refreshing which is not desirable.
I want to refresh the page only if user requested it manually.
facing same issue, If you got any solution then please share
I am having the same problem , anyone was able to find the solution ?
Having this problem also and it may be a deal killer for my company using Grafana. Any solution to this yet?
maybe set refresh interval here to be something very wide and force users to manual refresh?
Not sure what these intervals are or if they are related to the above intervals.
Or use other types of plugins with user initiated pulls but then again you might have someone hitting that fetch button x20000 times
Also have you looked into caching the already fetched data for reuse ?
I was also facing same issue and what I did to resolve this was to add Query result location from Athena Settings to allow me reuse my output and enable reuse query result from the editor but also in Grafana when you edit your panel theres a small check box that say Enable under Query result reuse, I enabled that and it seems to work perfect for me now
Follow the steps:
Step 1: Disable auto refresh(empty)
Step 2: Disable refresh live dashboard
Step 3: Hide Time Picker (Enable)
Step 4: Preload panels disable
Note: you can try this time option setting
