Grafana open source Grafana v11.1.3 (beac3bdbcb)
Disable auto refreshing for a specific dashboard (or at the very least set a custom minimum refresh for just that dashboard) as it takes a lot longer to load than all the other dashboards on the instance. The other dashboards refresh every 100ms but this one should only ever refresh on load.
I’ve tried setting the minimum auto refresh interval to 1 hour but then if you select auto it still tries to do it every 100ms which isn’t ideal.
Thanks in advance
George
