Auto-refresh lower than 5s
After I update the Grafana I cant set Auto-refresh interval lower than 5s.
Why they made that change and is there any way to make it lower than 5s?
See the changelog for version 7:
“Dashboard: A global minimum dashboard refresh interval is now enforced and
defaults to 5 seconds.”
I don’t know why - hopefully a developer can asnwer that - but I too would
like this change to be reverted.
Antony.
Thanks.
I really hope they change it back allowing us to set 1s interval at least.
Hi.
Thanks.
Do I need to edit this file or can I configure it through the Grafana UI?
Where Can I find the config file?
I would recommend to start with doc: https://grafana.com/docs/grafana/latest/installation/configuration/
I edited the grafana.ini and it not worked.
First, there was no min_refresh_interval variable.
So I inserted a new one and set the value to 1s
min_refresh_interval = 1s
Save the file and configured the Auto-refresh in the dashboard configuration UI to 1s,5s,10s but when I open the menu the 1s doesn’t show.
Which version you are on? As it works on 6.7.2
It certainly does work in 6.7.2, but see the changelog for version 7:
(Personally, I hope this restriction gets removed, but I have no information
about why it was thought to be a good idea to introduce it.)
Regards,
Antony.
Problem solved.
I use Linux and DietPi on a Raspberry Pi 3.
Guide for inexperience users like me.
You have to edit the /etc/grafana/grafana.ini using the command: nano /etc/grafana/grafana.ini
Then you have to look for the [dashboards] section and ADD a new line with: min_refresh_interval = 1s
You can use 1s or 100ms and other values.
Thanks all the helped me on the topic.
I’ve tried all solutions proposed here without results. I’m using Grafana 8.1.
I found the solution for this version. You need to create an Environment Variable
this has no sense,
why we need environment variable when natural settings are located into grafana.ini ?
I also wanted to chnage min interval to 1s. i followed below step.
but it didn’t show 1 s in menu.so i go to the dashboard settings. in there general settings i add 1s to the auto refresh time intervals like below.
it worked!
