Hello! Grafana 8.2.3—I have a dashboard with a logs panel that is querying our Loki datasource. I have the “Refresh live dashboards” enabled, but even when I have the time range set to the last five minutes I am not getting refreshes. Is there something else I could be doing? Also, is there a way to instead have the panel use the same “Live” functionality that the Explore page has?
First i would like to welcome you to the community, for your request i wonder if you tried with what is mentioned in this article :
Hope it helps.
Good Luck
