Grafana 10.1.5 -
I’ve a service which every 15 seconds sends metric (let say “alive”) to InfluxDB - it is a raw metric from telegraf, not agregated. I can read this metric and display it on “Stat”, “Stats Timeline” or “Status History” panel, all is ok. but… Based on that metric I’d like to show availability of my service. So… I’m using value mapping and it works as long as I’m using “fill(0)” in group by section…
value mapping 0 → Down works fine… but when I’m trying to change to “fill(null)” and use value mapping special (null) → Down… it doesn’t work.
Why I’m trying to use fill(null)? because I plan to use another feature of Stats timeline: Connect null values with specified threshold. -
What happened?
When I’m using group by: fill(0) value mapping: 0 → “Down” works.
When I’m using group by: fill(null) value mapping: special(null) → “Down” doesn’t work. -
Be able to use value mapping special (null) with fill(null) for group by.
Or… maybe I’m wrong. Maybe it is better option to achieve that. (Display availability status from raw metric (heartbeat) with 15 - 20 seconds interval but without false negatives at the end of observed time period.
