When I configure threshold colors and set the panel to have the background colored I can see a terrible gradient effect in the background. How to configure the panel not to have that gradient effect?
Please: show us what your configuration is and show us what the result is.
Antony.
Just set the threshold to a any color and set the color mode to background. See the background color has a gradient effect.
Anyone? Is it not possible to remove the gradient effect?
It’s definitely a bug in my opinion, and is more visible with certain colors (e.g. yellow seems the worst, green seems the least noticeable). Maybe this will be addressed in v8.0.
It’s a side-effect of the new color palette. We will likely need to add a checkbox to disable it.
I wasn’t able to disable it with any of the selections in field options.
Wondering if there is any way to patch this manually and build my instance with the patch? I believe it is not a simple change right?
this plugin has also been pulled out of core grafana into a new repo, you could fork it and rename the id: GitHub - grafana/singlestat-panel: Legacy singlestat panel (WIP!), that would easier than running a fork of grafana.
