I am getting seconds value in the stat panel. How to display it as mm:ss ?
Custom unit time:mm:ss is not working.
For example the value I have is 75, I want to see 01:15
Anyone? Is it not possible?
That is the issue, I need mm:ss and not HH:mm:ss.
Hi @tzn01,
As you have noticed, there is no default option for returning mm:ss and not HH:mm:ss.
We do, however, have a feature for custom units. The time:<format> option uses Moment.js, and these are the available formats. Unfortunately, I played with some options and I wasn’t able to return mm:ss. Any value over 60 minutes rolls up into the hours.
This is an interesting issue. You can open a feature request if you like.
Yeah I mentioned that I tried that too. No luck.
