Showing time format as mm:ss rather than default one how to configure?
Legend value calculation for time series graph where I would like to change
Just to be sure - you have a time series panel displaying some kind of duration (e.g. request duration or some job’s execution time) and you’d like to have the legend in hh:ss format instead of 2.1 hour, right? If so, this is the before:
(duration there is in seconds, don’t mind sample query)
After (notice the duration in Unit under Standard Options):
