SQL Server Monitoring Dashboard - by Florian Kinder
Hi, I am not sure if this is the right place to post my querey, I started using Grafana since 2 days. I downloaded the dashboard mentined in the subject, imported it in Grafana but it does not display any data. I have my Influx DB populated by telegraph as indicated in a config file
[[inputs.sqlserver]]
servers = [
“Server=192.168.1.69;Port=1433;Integrated Security = SSPI;app name=telegraf;log=1;”,
query_version = 2
This writes to tables such as
sql_cpu
sql_disk
sqlserver_database_io
sqlserver_memory_clerks
sqlserver_performance
sqlserver_server_properties
sqlserver_waitstats
which seems to me that this dashboard is looking/trying to look for data in other tables. Is it possible to get in touch with the author of the dasboard?
Thanks in advance
