Set Up Grafana on local
Can anyone help me to set up grafana with telegraf for SQL server monitoring on my local windows.
Really important.
i am not really understanding.
Your question is without any details, is there a specific step you are stuck on and need help with? Have you installed Grafana and have it running?
Docs for the Telegraf Sql Server plugin:
Hi…I kind of know how to run set up grafana and influx db now.
I have a working dashboard in my work place.They have imported the grafana dashboard from
So it is displaying what ever sql metrics as per the github code in here https://github.com/influxdata/telegraf/tree/master/plugins/inputs/sqlserver
I want to know if i can add any more metrics in addition to this?
not sure, check telefgraf & the telegraf plugin docs
