I’ve recently been learning about Grafana and using it to make try to make charts for my InfluxDB and Telegraf stack and have run in to problems with one of the pre-made dashboards - Specifically the SQL monitoring one located at this location
Some of the stats are not populating when I view the dashboard. Mainly the first row with Database Health, online, offline and there is more but my issue is with the ONLINE/OFFLINE.
No stats are pulled through to those panels, but if i alter the query then i can get data into the panels but i am unable to save the dashboard. Each time i do i get an error message
'Invalid Alert Data'
When I check the grafana logs i see an error about Alert Frequncy
Failed to extract alert.Reason: Could not parse frequency
I’ve looked at the panels and dashboards and i dont have any alerts set up with Grafana so i am becoming a bit confused as to why i am getting this error.
The original query from the dashboard:
SELECT "total" FROM "State ONLINE" WHERE "servername" =~ /$Instance$/ AND "type" = 'Database properties' AND $timeFilter
The query i have tried to add:This one is taken from Chronograf - But that is how i usually get my queries.
SELECT "Total" FROM "telegraf"."autogen"."State ONLINE" WHERE time > now() - 1h AND "servername"='WIN-***********'
I can provide more info as needed, i wasn’t sure what info would be relevant but if someone can help i’m happy to get the info needed.
PS: There were only 3 tags to choose from, none of them really seemed to fit.
Regards
philb
