anyone using otel collector to send springboot(2.x) app metrics into grafana.com
im using below in processor otel.conf
but metrics inside grafana are showing job value as “java/myapp” instead of “myapp” as per below
other attributes do not have this issue
only job value gets namespace/myapp as attribute for job attribute ?
im deploying app in aws beanstalk using otelcol as second container ,
I will try to retest using public image app using docker compose and then in beanstalk to compare if its only happening in aws beanstalk environment.
tested removing namespace value and then job value is exactly whats defined without namespace/jobvalue like below
- action: insert
key: job
value: "sbdemo-dev1"
you can test with any demo app using these in docker-compose
OTEL_RESOURCE_ATTRIBUTES=service.name=sbdemo-dev1,service.namespace=java1,job=sbdemo-dev1,application=sbdemo-dev1
processors:
batch:
send_batch_size: 10 # Number of objects which will be sent in each batch
#send_batch_size: 8192 # Number of objects which will be sent in each batch
timeout: 10s # Time after which a batch will be sent anyway, regardless of size
send_batch_max_size: 0 # Upper limit of the batch size, 0=no upper limit
attributes:
actions:
- action: insert
key: env
value: "dev"
- action: insert
key: application
- action: insert
key: job
- action: insert
key: instance
- action: insert
key: service.name
#- action: insert
# key: service.namespace
# value: "java"
- action: insert
key: service.version
value: "1.0.0"
- action: insert
key: deployment.environment
value: "dev"
However, <service.namespace>/<service.name> or <service.name> (if namespace is empty), is added as job label and service.instance.id is added as instance label to every metric.
the default springboot dashboard for metrics is not picking up all metrics , will need some changes
posted another thread below
