we are pushing metrics to grafana cloud using opentelemetry collector, and application are using javaagent (auto instrumentation) this is regarding deployement.environment resource attribute which ended up in the target_info metric and how to join http_server_duration_milliseconds_count metric with target_info metric for environment based dashboard
Hi! To avoid joining queries with target_info I would recommend using a transform processor in the collector to add the deployment.environment attribute to the Prometheus metrics as a label (deployment_environment):
transform/add_resource_attributes_as_metric_attributes:
error_mode: ignore
metric_statements:
- context: datapoint
statements:
- set(attributes["deployment.environment"], resource.attributes["deployment.environment"])
service:
pipelines:
metrics:
receivers: [otlp]
processors: [transform/add_resource_attributes_as_metric_attributes]
exporters: [prometheusremotewrite]
thanks for solution, but when i use as it is, collector not starting… can you please point me to full configuration file (/etc/otelcol-contrib/config.yaml)
never mind it is working with following configuration
transform:
error_mode: ignore
metric_statements:
statements:
service:
pipelines:
metrics:
receivers: [otlp]
processors: [transform]
Did you get an answer? I am facing the same problem on my project, if you find the solution please share here.
