I’m starting to explore loki and I have few questions.
I’m using docker.io/grafana/loki:2.8.2 container image.
Here’s my configuration (mostly copied from s3 example):
auth_enabled: false
storage_config:
aws:
bucketnames: "${S3_BUCKET}"
endpoint: "${S3_ENDPOINT}"
region: "${S3_REGION}"
access_key_id: "${S3_ACCESS_KEY_ID}"
secret_access_key: "${S3_SECRET_ACCESS_KEY}"
boltdb_shipper:
active_index_directory: "/loki/index"
shared_store: "s3"
cache_location: "/loki/index_cache"
schema_config:
configs:
store: "boltdb-shipper"
object_store: "s3"
schema: "v11"
index:
prefix: "index_"
period: "24h"
compactor:
working_directory: "/loki/compactor"
shared_store: "s3"
common:
ring:
instance_addr: "127.0.0.1"
kvstore:
store: "inmemory"
replication_factor: 1
path_prefix: "/loki"
So my questions are:
with this configuration I’m getting three warnings which are not really clear to me:
level=warn ts=2023-05-30T01:12:44.887370251Z caller=loki.go:286 msg="per-tenant timeout not configured, using default engine timeout (\"5m0s\"). This behavior will change in the next major to always use the default per-tenant timeout (\"5m\")."
level=warn ts=2023-05-30T01:12:44.890365158Z caller=cache.go:114 msg="fifocache config is deprecated. use embedded-cache instead"
level=warn ts=2023-05-30T01:12:44.890392698Z caller=experimental.go:20 msg="experimental feature in use" feature="In-memory (FIFO) cache - chunksembedded-cache"
How do I fix those warnings?
Second question is about /loki volume. I can see that loki creates several subdirectories inside /loki directory. I want to understand how should I treat this volume? I thought that it should be just something like tmpfs which will be discarded, because I configured S3 storage. But I can see that there’s something like /loki/wal/00000001 inside which looks like legitimate data.
So should I configure my system to provide persistent storage for this volume, despite the fact that S3 is used for log storage?
