Hey! I’ve been trying out Loki and i’m running into some issues.
this is my loki configuration:
auth_enabled: false
server:
http_listen_port: 3100
log_level: error
common:
instance_addr:
path_prefix: /loki
storage:
filesystem:
chunks_directory: /loki/chunks
rules_directory: /loki/rules
replication_factor: 1
ring:
kvstore:
store: inmemory
schema_config:
configs:
store: tsdb
object_store: filesystem
schema: v13
index:
prefix: index_
period: 24h
ruler:
alertmanager_url:
limits_config:
ingestion_rate_mb: 100
querier:
max_concurrent: 512
query_scheduler:
max_outstanding_requests_per_tenant: 512127.0.0.1http://localhost:9093
And I have a grafana dasboard set up where I do a bunch of queries like these:
{source=~"$source", swarm_stack=~"$swarm_stack", swarm_service=~"$swarm_service"} |= `$searchable_pattern`
Which is kind of nice, because it allows me to filter by stdout/stderr or by stack of service in the dashboard.
Data is ingested by promtail and the loki docker plugin.
Now the issues i’m encountering are:
- If Loki/grafana wants to query some log entry that is too long (~1 MB) it crashes, and isnt able to display it. → Is there some way to just cut off long log lines? Or should Loki be able to handle this?
- I log quite a lot, around a million entries a day. If I do anything in the dashboard that processes more than 2 days worth of information, Loki takes up 100% CPU, and somehow causes all docker services on the same server to become unavailable/unresponsive. Causing me to have to restart. → What could cause this? Is it the regex’es is my queries? Or have I configured Loki in some sub-optimal way?
Thanks! ![]()
