Help with my S3 configuration
I’m currently using Loki version 3.2.1 with Docker Compose, and I need assistance with a configuration issue. My Loki configuration is as follows:
auth_enabled: false
server:
  http_listen_port: 3100
  log_level: info
  grpc_listen_port: 9095
query_range:
  parallelise_shardable_queries: true
querier:
  max_concurrent: 1024
frontend:
  max_outstanding_per_tenant: 1024
  compress_responses: true
compactor:
  working_directory: ./data/loki/compactor
  retention_enabled: false
  retention_delete_delay: 2h
  compaction_interval: 1m
ingester:
  chunk_encoding: snappy
  wal:
    dir: ./data/loki/wal
  lifecycler:
    ring:
      kvstore:
        store: inmemory
      replication_factor: 1
  chunk_idle_period: 5m
  max_chunk_age: 1h
  chunk_target_size: 1536000
  chunk_retain_period: 30s
schema_config:
  configs:
      store: tsdb
      object_store: s3
      schema: v13
      index:
        prefix: index_
        period: 24h
storage_config:
  tsdb_shipper:
    active_index_directory: /tmp/loki/tsdb-active
    cache_location: /tmp/loki/tsdb-cache
  aws:
    s3: "s3://${S3_BUCKET_NAME}"
    region: "${AWS_REGION}"
    access_key_id: "${AWS_ACCESS_KEY_ID}"
    secret_access_key: "${AWS_SECRET_ACCESS_KEY}"
limits_config:
  max_query_series: 1000000
  max_entries_limit_per_query: 1000000
  split_queries_by_interval: 5m
  max_label_name_length: 100
  max_label_value_length: 100
  reject_old_samples: true
  reject_old_samples_max_age: 72h
  ingestion_rate_mb: 20
  ingestion_burst_size_mb: 40
  max_query_parallelism: 100
  query_timeout: 30m
  allow_structured_metadata: false
table_manager:
  retention_deletes_enabled: false
  retention_period: 336h
The environment variables, AWS keys, and S3 bucket configurations are all correctly set up and working as expected. However, I am encountering the following error in the logs:
level=error ts=2024-11-18T17:30:32.806075185Z caller=cached_client.go:189 msg="failed to build table names cache" err="InvalidParameter: 1 validation error(s) found.\n- minimum field size of 1, ListObjectsV2Input.Bucket.\n"
level=error ts=2024-11-18T17:14:17.796946776Z caller=compactor.go:544 msg="failed to run compaction" err="failed to list tables: InvalidParameter: 1 validation error(s) found.\n- minimum field size of 1, ListObjectsV2Input.Bucket.\n"
I entered with docker exec -it loki sh and checked, and the environment variables are correct. Also, I downloaded an Amazon AWS CLI inside the Loki container, and the connection to the bucket and permissions are working. Thanks in advance for your help!
Try this:
schema_config:
  configs:
      store: tsdb
      object_store: aws
      # object_store: s3
      schema: v13
      index:
        prefix: index_
        period: 24h
