Snapshot shows not all Data (Datasource MS SQL Server)
I have a Dashboard with a lot of Panels and within a MS SQL Datasource to get the Metrics.
When i create a local Dashboard Snapshot, some Panels show “No Data”.Increasing the timeout value brings only partial success. There are still panels with no data
any suggestions ?
thanks Stefan
  • What is your Grafana version?
    v7.5.7
  • Are you using Grafana Cloud or self-hosted Grafana?
    self hosted
I have this issue as well. I’m on v8.2.5 and we have a repeating panel, when the snapshot is viewed, only 5 of the 8 repeated panels show data. The others show “no data”. This happens similarly on other parts of the dashboard as well.
Is this currently an outstanding bug? Am I doing something wrong?
Same issue here: Graphana v8.5.2 self hosted, data source = Infinity.
The problem is both in locally stored snapshots & snapshots on the cloud, but there are some differences between the two, which I hope will help to investigate this issue:
  • More panels (but not all of them) are shown with data when publishing the snapshot to the cloud (snapshots.raintank.io) as compared to locally.
  • Locally stored snapshot has panel with “Unknown Query Type” & no data is shown also in right click->“Inspect”. While in snapshots stored in cloud, partial data (“A-series”) is shown in right click->“Inspect” (but data is still missing in the panel itself).
I used Prometheus as data source, Grafana 8.4.5
Having the same issue, It reproduces only in case when wide data ranges are used to save snapshots.
As work-around, I increase snapshot timeout, looks that helps…
The issue is that Grafana only creates the snapshot for panels that are so-called “in-view”.
So in order to have all panels in snapshot - zoom out the screen. Or rotate the display :slight_smile:
Yes, this is how it designed and works…! Is there any option to change default 4 seconds to some higher value for this Snapshot creation Timeout? Most of my dashboards require minimum 10 seconds. So i would like to increase. Do share if any way for this.
