Problem with MS SQL Dashboard (9386)
Hi there - i just started to play with Grafana and tried to use it for showing some stats for our SQL Server Enviroment.
But somehow - it wont show stats for some panels
Access Methods are blank - and also the DATA Read/Write Panels
Here is the link to the dashboard.
GOt any suggestions how to “repair” it
Hi @marcusberka ,
I’d say that it’s not uncommon to have some broken panels when you import a third-party dashboard.
Do any errors appear on your panels? If so, what do they say? Anything interesting show up in the logs?
Hi I have the same problem
some data is displayed others not:
Thanks for any advice
