Slack notification Grafana 9 not working
Grafana 9, containerized on Ubuntu server.
Receive proper alert over slack channel.
I have created a connection to our Slack channel, and tested several slack templates.
  • What happened?
The notification are not working, they don’t display any data, and if we use the default, the content its illegible
Before we upgrade to Grafana latest version, we had a Notification Chanel were we configure the same for slack, now the same is no longer available, and the notifications are complex to be configure.
Before upgrading, Grafana v8.0.7
After Upgrading, Grafana 9 latest version.
I didn’t found any errors/issues after upgrading.
I followed the Grafana documentation to upgrade through docker compose.
We have exactly the same problem, but with Google Chat. Before the upgrade, the alerts were nicely formatted. Now they look like your Grafana 9 screenshot, where all properties are just bundled together.
Hoping for help or a fix.
So a solution for this will be a downgrade, the main issue it’s on the v8.x.x were found security breaches and it is recommended to update to it latest version. Hope we get a hotfix soon. I’ve also reded the release notes for the newest version 9.0.2 but there is no mention to this behavior
Info regarding the sec breaches.
I created a response to another post yesterday on this topic, it has steps to help you format the labels in the alert
