Grafana 8.01-beta2 -
Trying to utilize Message Templates to deliver alerts via slack (using webhook) -
I was using documentation to configure message templates. -
What happened?
Everything more or less works for “Templated title of the slack message”, but I can’t get it to work when I use template for Body Text.
I would expect Slack contact point to be using Message Template for Body Text as well -
Slack contact point configuration
Message templates
Nothing specific. No errors. -
Message templating | Grafana documentation -
Additionally:
I haven’t find the way how to pass “A” query value to the alerts message.
I would appreciate any help!
