Grafana 8 Alert not working as expected
I have upgraded Grafana from 7.4 to 8.1.5 with the new alerting mechanism.
The ‘new alerting’ not working properly (also not so intuitive imo)
There is no testing button in order to test connection (should be coming out soon afaik)
    Grafana 8.1.5 - docker image - alpine
    I’m trying to test a new alert (using the new ngalert)
    Defined dashboard
    Defined contact point (slack channel → webhook is properly configured as ‘curl’ command running successfully)
    Defined Notification policy
    Defined proper labelling matching between the notification-policy and alert labelling.
    Triggered the alert → ALERT WAS FIRING PROPERLY
    But did not send the alert to slack
  • What happened?
    Alert was not sent to slack notification
    Expected to receive slack notification
    new NGALERTS not working properly
    No errors
    Create Grafana managed alert rule | Grafana documentation
How can I make sure connection with slack is ok ?
What exactly should be with the labeling in notification policy? I see every alert get label “alertname” → should it be part of the notification policy ?
Thanks.
I think this could explain your issue: [ngalert] Missing alert notifications in Grafana 8.1.3 and 8.1.4 · Issue #39295 · grafana/grafana · GitHub
the tl;dr is that it’s a bug that manifests if your alert evaluation interval is 30s or more. It just got fixed in 8.1.7: Release notes for Grafana 8.1.7 | Grafana Labs
I was blocked by this for a long time until I found that issue thread. I hope this helps.
will give it a try, thank you!!
