Hello Grafana forum,
I’m using singlestat panel with query to influxdb: SELECT "any_field" FROM "any_measurements" without $timeFilter
with setting: Value=Time of last point, Unit=YYYY-MM-DD HH:mm:ss
basically I just want to know timestamp of last available data in my measurement.
Right now it’s working okay, but it only showing the time (h:m:s) when date is still same as local time.Can I force show it on full timestamp format instead? I want to avoid confusion to the viewer by showing only the time without date information. Thanks.
