Grafana 7 - Stat panel - Time of last point
When migrate Singlestat panel to new Stat panel, I can’t find the “Time of last point” option in view anymore.
Ver. 6.3.6:
Selezione_108
Ver 7.0 (I can’t find Time of last point)
Selezione_109
I have the same issue with Grafana 7.0 and the fact that “Time of last point” option is missing in the new single stats plugin.
single-stat before migration:
single-stat after migration
Another difference in the background:
It’s not very serious, but you could put an option to choose between the 2 modes.
If it is too complicated I think the display of version 6.3.6 is much better.
I ran into this too.
Is there a way to do “Time of last point” with the new Singlestat panel, or with transforms, or has this functionality been lost?
I tried everything that came to my mind but I couldn’t get the “time of last point”
Unfortunately for me this is strongly blocking :pensive: :pensive:
There are other minor issues as well, but this prevents me from upgrading to grafana 7
I struggled with this too and somehow came up with a solution (using mysql and grafana 7.0.3).
This only works for Table Series though, in Time Series the Time value is rigorously ignored- I dont know whats going on there.
My DB field is of type datetime and I just save the mysql current_timestamp().
In Grafana I select the column and cast $__time(), then override unit as From now.
Here is an example using the query-builder, Ive also tested with raw sql which also works fine:
I solved this by using Value “Last” and adding “relative time” (with value “5m” = last 5 minutes) to “Query options” (Query and transform data | Grafana documentation) since I want to display current/latest value only (regardless the selected time frame).
There is official solution to this ?
I would like to have a timestamp as well to see when the last update of data happened
Select the time field if you want to display the time of last data point
this is my situation:
In my DB I have:
time value
1600773900000000000 1600773900
1600774200000000000 1600774200
And I want to show “X minutes ago” using “value” field.
I’m using the latest version of Grafana.
What am I doing wrong?
Thanks
Is there a way we can see the time between “now” and “time of last value” on Grafana 7?
Thanks
