I have complex Postgres query with single row and two columns (Time and Value). I would like to know if its possible to show value and last time the value was reported in SingleStat Panel.
yes, it possible, in the options tab in the ‘stat’ parameter you can choose the date of the last data.
you can use two panels, one for value and another for the time
Thank you for reply and so I would assume we can not make it happen using single panel. can any other panel serve what I need? I’m basically wanting to show value and show the time below the value to show when was the last time we received the data.
