Singlestat Panel - Different values according to Time Range
I have a problem with the Singlestat panel. My panel is on “Current” so it must be the last value which is displayed on the panel but when I change the Time Range (for example when I change “Last 30 days” to “Last 1 hour” I don’t have the same value and it is very problematic.
Any answer/solution to this?
I have the same problem.If I expand the time range (for example when I change “Last 1 hour” to “Last 15days ”) the graph will change and some value will be lost,even the current value will become inaccurate.If you have solved the problem,can you help me? Thank you!
