i cannot achieve to have a Singlestat Panel with real-time data refresh.
I use postgresql as data source.
I have written a simple query that extract 1 text value and it’s correctly displayed on my panel but when I change thet value on db the panel doesn’t refresh automatically as i expected.
I know there’s something i’m missing, but what?
Singlestat panel only works with numeric values that can be mapped to string values. Please include your query here for further support.
Thanks
Marcus
Hi mefraimsson,
i have a simple singlstat panel with a gauge that display this metric:
SELECT
oee
FROM
iot40.“Counters”
from a postgres database.
I like to see the value changing on the dashboard when i change it on db.
Is it possible?
You want to use a time-series query as explained in documentation.
Something similar to
SELECT
$__timeSec(now()),
oee as value
FROM
iot40.“Counters”
LIMIT 1
But if oee column is a string I don’t think it will work, but give it a try.
Marcus
The value in gauge is correctly showen but the value is not updated
What is the value displayed?
If you have some column (date or primary key) that you can use to order the result by I would suggest that, i.e. ORDER BY <column>.
Marcus
My table i so simple, it has this structure:
oee,total_producted,last_run,availability,total_ok,quality_sum,total_cycles,quality,total_faults,performance,total_count
0.9292735496852251,1178057,63,0.9900136909076266,12355,12284.837987103772,12417,0.9893563652334519,62,0.9487452685833937,1241700
i’m thinking i miss something in working model…
Cool. I answered with that query 3 days ago
Yes,
but i’am too stupid to change the time picker, sorry for wasting your time mefraimsson and thank you again
No worries. Glad you sorted it out.
