i began of using Grafana to visualise date from my zabbix server. I’m getting CPU utilization data per core, but i would like to show chart only for mean / average value. So instead of 36 series i would like to have one with mean / average value.
Try learning about the “Functions” feature of the zabbix integration at the docs. In special, for your case, try playing arround with sumSeries and aggregateBy.
If you can’t make it work, another thing that you can try is messing arround with the transformation.
