I am trying to create a widget which use Zabbix Web Scenario as datasource that will show HTTP Code + My value map, now where my problem start is that I am unable to show the HTTP Code with the value map I have done. I would like the panel to show the HTTP Code + the value map I have created. Just like that “Error 404 ebsys.be” “Error 403 ebsys.be” “OK 200 ebsys.be”, I don’t know if it’s clear but that would be very nice, thanks.
