How can define text filter regex
My last data thta is showing in grafana is such as follow :slight_smile:
HTTP OK: HTTP/1.1 200 - 14716 bytes in 0.011 second response time |time=0.010866s;5.000000;10.000000;0.000000 size=14716B;;;0
so I want to define it in grafana in Stat panel if find 200 show UP and if could not find 200 show service down . How can define value mappring regex for while cannot find 200 ?
Hi, if you’re using value mappings, you can always do:
Mapping 1 β†’ regex .200. β†’ Service UP
Mapping 2 β†’ regex .* β†’ Service Down
the mappings are executed in order, so it will match the first rule.
In your Stat panel β†’ Edit β†’ Value mappings β†’ Add these two regex mappings:
Show UP (when 200 found)
Type: Regex
Pattern: .*200.*
Display: UP
Color: Green
Show Service Down (when 200 NOT found)
Type: Regex
Pattern: ^(?!.*200).*$ or better option .*
Display: Service Down
Color: Red
Mappings are executed in order β†’ Mapping 1 is checked first. If it matches, Mapping 2 is skipped.
^(?!.*200).*$ β†’ explicitly matches strings without 200
.* β†’ catches everything that didn’t match Mapping 1
That is strange . It does not work .
Add value mapping
Add new mappting as regex . then in regulat expression fill with .*200.*
and optional diplay text fill with UP but still showing 200 instead of UP
Could you share a screenshot of your Value Mappings configuration and the panel query result?
The regex mapping shown above works when the field value is a string containing 200 (for example, HTTP/1.1 200 OK).
If your panel value is the numeric value 200, then a Value mapping may be required instead:
Type: Value
Value: 200
Display text: UP
Could you also share the panel configuration or Query Inspector β†’ Data output so we can verify whether the field is being returned as a string or a numeric value?
While my output is string such as :
That regex is working but while output is not string and just return 200 that regex does not work .
How can set Down when out put is any thing except 200
.* Regex does work on numeric values in Grafana. Use these two mappings:
Mapping 1 β†’ UP:
Mapping 2 β†’ catches EVERYTHING except 200:
Grafana executes mappings in order β†’ if value is 200 β†’ shows UP and stops. Anything else (404, 500, 600, null) β†’ caught by .* β†’ shows Service Down.
This works for both string and numeric output
Please find follow pics due define regex for output 200 it does not work while define regex
I was able to reproduce similar behavior with a numeric Zabbix item.
In my testing:
Value mappings (for example, 200 β†’ UP) were applied correctly.
Regex mappings such as 200, .*, and ^.*$ were not applied to the numeric value, and the panel continued to display the raw value (200, 500, etc.).
try changing your mapping from Regex to Value?
UP mapping
  • Type: Value
  • Value: 200
  • Display text: UP
  • Color: Green
If you need to handle other status codes, add additional Value mappings for those codes as well.
Based on the behavior I observed, this appears to be related to how value mappings are being applied to a numeric field rather than an issue with the regex pattern itself
This is my output :
HTTP/1.1 302 Found
Connection: keep-alive
Content-Length: 0
Date: Tue, 23 Jun 2026 06:04:28 GMT
HTTP/1.1 200 OK
Cache-Control: no-cache
Set-Cookie: JSESSIONID=7PpXWGxP-nfUiq-AQHacZMdoxTtCrnccJ3-QAKVm.app; path=/data
Content-Type: text/html;charset=UTF-8
Content-Length: 4759
So I defined follow regex . but it does not work . What is the issue ?
What happens when you convert the values to string bevore the mapping? Normaly that helps. Regex expects a string souce.
